Thinking of adding a 50 shot of nitrous
run stock timing but run race gas with nitrous IMO.
If you want to run a 50 shot on pump gas, and you know your car is running right (sane afr, etc) then run about 14 degrees of timing. If you are still on a stock pulley you should be able to spray 50 at pump gas assuming your afr's are happy.
I usually pull out about 2* for every 50 shot. But, you have to monitor...the ultimate answer will depend on your fuel, shot size, and car in general.
epic switch setup. What did you tap into for the fuel line? And did you do any timing for over a 50 shot?
Forgot about this thread. Sorry about that. On the above NX kit I simply removed the schrader valve from the test port off the fuel rail and then ran the line to the fuel solenoid. The kit does the rest, but just remember if you unhook the kit make sure and put the valve back in. You can get the valve removal tool from autozone, IIRC I used a tire stem valve removal tool.
That's what I did on my G8 for the fuel line. Having a test port makes it very easy. I think I'll get a universal kit from zex or NX or whoever and go from there. I'll have to find someone who can give me different tunes for a 50, 75, and 100 shot.
Anyone have any recommendations for a WOT switch? On my G8 it was electronic so it was a lot easier to wire up instead of mechanically cable driven.
I was looking at that one, thought it looked pretty good. I was reading on 3800 pro, that dude said he didn't feel much until he went to the 75 shot because of the intercooler, have you heard of anyone else talking about similar situations?
