Delilah....dyno rackar
Re: Her names Delilah
LS4 decals are here!!!! Personally I think they look way better than that stupid expensive 50 dollar ones!!!
Hey guys...lookie what I found :)
Waiting so I can go next...lol I'm trying to figure how and the hell those are "kind" of plug and play when I had a bumper off relocating my coolant resoivoir tranny cooler etc I looked at the fog assembly and it didn't seem like fusions would be a easy upgrade per say.Some fab work will be neccesary
we shall see. i was told they were easy to install in gxp. ill set the old and the fusions side by side for a comparison...give me a few minutes im headed out to take the olds out and then picks will follow for ya
FYI it might be better to snatch the bumper off to get this done it shouldn't take long 15min all you'll need is 10mm ratchet door panel removal tool and 7.5mm socket for the fender portion
How did u take out the piece that the fogs are in when u did it? I already got the fog lights out and all but if I could just take that one front section of the bumper out utd be a lot easier
Niccccce so I'm assuming you just desperate the buckets/housing and swap the Gxp one on the fusion one?
I dunno at this point...I'm waiting on the guy to message me back he said he'd be on to help...id doest look like its swappable
Wanna see this when your done, keep on swimming lol
I will...I gotta go to a formation then I'll be back working on them. I'm gonna take a detailed pictures for y'all that are also interested in doing these. The new ones look way better inside and out compared to old
From the pics it looks to be just heating up both housings separate them swap the back half of the Gxp housing to the fusion and reseal or if u wanted The adjustability of the for bracket you'd have to cut the bumper fog light surrounds and and then mount them in there which is way to much work.
That's with the adjuster part on the new fusions off side By side with old one
I'm also gonna wait for him to message me before I start heating sh*t up cause he said it wasn't hard at all
It takes a little creativity. The sizes of everything match up perfectly. You just have to mock it up to see what the best way you want to mount it is. This is a first for GXP owners, I know that for a fact. So I'm not saying that the way I did it is the best way because it by no means is. I want to play around with it more and see if there is in fact a better way to do it. It all lines up, it's just a matter of implementing it correctly.
Creativity lol. It would help if I could take the place on the front bumper put. The stuff that 91parkave replaced with mesh were the fogs are.
Alright guys and gals that want these. I got the honeycomb in the front of car around fogs out...made it 1000x easier to work on. All in all to mount these you'll just have to drill two holes for mounting them to the stock ones. When I turned them on and compared with old fog lights the difference is extremely noticeable and I even think a set of hid's will greatly improve these even more. I won't be able to drill holes for mounting them tomorrow...but Saturday I most definitely will.
Stay tuned for pics tomorrow sometime...probably evening time frame. I'll give some good angles of how to mount them and all and I haven't finished yet but still recommend them for gxps just cause what I've already seen
