Only two control arms on your car. The rear uses a setup of lateral link rods and trailing arms.
No spring compressor needed. It's really self explanatory. Remove ball joint nut, pry ball joint from knuckle, remove front bushing bolt, remove rear bushing bolt, installation is the reverse of removal. I'm sure someone on here can get you the proper torque specs.
Recommended practice for tightening the two pivot bolts is to put them on, but not tight. Once the ball joint is done, use a floor jack to compress the suspension to normal ride height, and then you tighten the pivot bolts to specs.
i was told i needed a rear stabilizer, is that what you talking about?
