What did you do to your Car today?
Status
Not open for further replies.
i would get a backup haha, i never ever thought id lose my key, all it takes is one more beer then u shoulda had and boom gone haha
And 5 more beers, you'll lose the car an report it stolen... Only to find you drunkenly drove over to the grocery store(across the street from the police station) and the po po put a boot on it.
Try this
30 Minute Relearn Procedure (Steps): This is for a "replacement" (new) key (no original available)
1) Insert a "Master" Passkey III (PK3) Key (the one with the black plastic cover as shown above).
2) Turn the Ignition to ON, but do NOT start the engine. You should see the "Security" message on the dash for about 10 minutes and then it will turn off.
3) Turn OFF the Ignition and wait 5 seconds.
4) Repeat the above steps (1-3) a total of 3 times, or a total of 30 minutes.
5) After the third time (including turning back to the OFF position), start the van. The van should now have "learned" the transponder information and will allow it to start and continue to run.
Important Notes:
- When the above procedure is used, all previously learned keys will be erased from system memory.
- Additional keys can be learned immediately after the relearn procedure. This is done by inserting the additional key and turning the ignition to the RUN position within 10 seconds of removing the previously learned key
How is a Fob programmed exactly? Mine is super weak, only works about 3 feet away from the car
most of the time its pretty easy to re program a fob, the newer years GP's, well sorry guys lol directions should be in the owners manual, if you dont have one, they are on line for free.
weak fob could be a bad battery, or the buttons need to be cleaned.
i got my car with one key for the doors, and one for the ignition, thats it.
first thing i did was get another key, and a fob. i know me, id lock it in the car, or loose it sooner or later lol
Try this
Important Notes:
Is this only for the key itself or the fob?
Tried a new battery. Ill try cleaning buttons.
Try this
Important Notes:
well this didnt work, looks like im payin up the ass to get it programmed lol
Ok almost finished the CAI install, just have to extend the IAT wire and done under the hood. :th_mechanic: , second pic is with headlight installed showing there's lots of room, and third pics is my air pressure gauge I painted to match the car - and yup that is the one I thought I lost but was down in the center console.
Status
