squeeking when turning?
Timing
So now that the warm weather is coming ive been noticing a squeeling/squeeking type sound from my front right when i turn. Ive recently replaced my bearing cv axle rotors pads. control arms and tie rods look ok. Its like pulsing squeek like a cv axle but ive replaced it twice cus the first one was leaking and it did it with both. Could it be a ball joint, bad rotors, caliper or something. i also noticed my dam brakes squeeking to when i brake. Think i put semi metallic in there so ima replace with ceramics and see if the problem persists.
and yes i lubed the pads and pins up
