importisland13
Banned
Re: Red 2006 Grand Prix GT Supercharged Retrofit En Route(Lowered, Rims & Aeroforce)
dammmm car look really fkuking good lol
lol goodluck might have to pay u to do my lights like that lol
Haha I don't know the first thing to do with them lol. I still haven't done these so well see.wannna do my foglights retrofit
If condensation develops in the headlight that means the headlight was not sealed correctly. I had this problem the first time I ever put my lights together. Instead of heating up the headlights again to reseal them I just used window weld(almost identical stuff except you can apply it without heat) to reseal my headlights. Never had a problem after that.
Thanks man, i painted the shroud hopefully can keep it chrome. Thanks for the how to, makes it a lot easier! N I seen the clips to take them off but I always have bad luck with the clips and break them! Didnt wanna take a chance n had the tape n time. I have a question about the projector going in the headlight tho, is it going to be sticking out about a half inch or so, or did you trim the diameter more to have the projectors sit back a little further in? N your guess about the heat from the lamps n headlights seem logical, I just dont know, would that create the pressure great enough to separate the glue. Is possible tho maybe.Looking good so far, liking the retro and it seems to be nice in all chrome.
Just so you know....the rear valence unclips out of the car without too much effort.![]()
Ohhh nice. I bought the rubber butyl but just at home depot im assuming I can get the window weld. Does it get applied like yhe glue does as well?If condensation develops in the headlight that means the headlight was not sealed correctly. I had this problem the first time I ever put my lights together. Instead of heating up the headlights again to reseal them I just used window weld(almost identical stuff except you can apply it without heat) to reseal my headlights. Never had a problem after that.
If your planning on using the rubber butyl you will have to apply the butyl then heat the headlight for so long then put the headlight together. If you were to use the window weld stuff you just apply like using calk then squish the headlight together with clamps for 5hrs or so then done. In my opinion I would use window weld cause it is a lot easier to work with but that is just me. Either way will work.
GrandPrix06GT;Ohhh nice. I bought the rubber butyl but just at home depot im assuming I can get the window weld. Does it get applied like yhe glue does as well?[/QUOTE said:
Yeah the projector should stick out a little, I've noticed with the H1's they don't sit back as far as the D2s projectors.
