Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
stock replacements ARE ls7 lifters... thats all GM sells. One lifter short of the crazy racing lifters.
So make sure you buy a pushrod length checker or buy some comp lifters and again, pushrod length checker, and install the correct length lifters.
Either my lifters were **** or the oiling holes were in the wrong place. Talking to a local, it seems the oiling port was probably in the wrong spot so they starved on oil and seized.
Goodluck either way. I don't know what the **** was going on there, nor did I honestly have the patience to figure it out. I needed the car, and after a month, I parted it out and got far more than I imagined I would.
If everything else is stock size, (head gaskets, rockers, valve height etc no or very minimal taken off head surfaces) then the stock 7.050" pushrods should work fine with ls7 lifters. They are pretty forgiving with preload compared to the comp oe-r's that some run. I would run ls7's or good low mileage stock takeoffs. Just my 2cents.
