Wheres the xtra batt and amp(s) fitting?? Lol. That's pretty big box for grand prix trunk... Most I've ever been able to fit in through trunk was 4.2cuft ish.. Did a 4 12 sealed set up awhile back.. 5.75cuft ish was two different shaped boxes but had same amount ain't of air space... That sounded good on EVERYTHING! Qtc was at .707.
Op would you happen to have the cut sheet?? And what wood is that??
my amp for the bl is an american bass vfl 4480 so it's tiny. that helps a bit with space. I used to have two beefy olds school mtx 2 channel amps for my mids and highs but now I just have a newer model alpine 4 channel, which isn't that big (physically) either. and no extra batt yet, hopefully by the summer...
The 4480 is a GREAT amp!! Would u happen to have a cut sheet for that box? I would highly recommend an extra battery maybe two for that amp
yeah, I've heard it can put out some power. i was surprised at how small it is lol. you think I should get two extra batts? I was thinking 1 big batt in the trunk would be enough with the 200a alt.
and not sure if you missed my post above yours about not having the cut sheet...
edit. I could ask my builder to email me the cut sheet if you want
Yes please do that!! Would love to see and try it out... Did you have to remove any seats to get it it??
yes, i removed my rear seat and slid the box in through that opening. once the box is in, I can put the rear seat back in, however, I plan to leave it out
I knew the rear seat had to come out but what about the driver or passenger seat??? My cars a 2door...
