GTP89
Well i finally fixed and sold my grey gtp now it is time for the VS cam build to go on my 40th NA. I Will be doing a L67 swap but wanted to know what it is that i need to even run the L67 as far as i know this is my list.
Radiator
harness or plug adapter from zzp or make my own.
pcm which i have
add performance shift to it
I think that is it as far as the swap goes now the cam Install.
Vs Cam Duh..- check
90 Yellow Springs - check
New single timing chain - Check
Tensioner - Check
Ls1 retainers
42 injectors
Now as far as i know that is all and what i need for the cam install is the retainers and injectors. My question here is are manley retainers and LS1 retainers the same?
Next question what trans parts do i need to hold up more then enough max i am hopping to get is 320-350whp?
Do i really need the 7/8th chain setup?
4340 input shaft?
Harden 4th?
Shift kit do any good?
Next i have slp Headers and was wondering is there any harm by wrapping them with header wrap?
Last question should i leave the heads as they are or get the valves freshened up and do some slight home port work on them? If so how difficult is it to do porting on them is it a delicate process?
Some pics engine is all stock and has 100k on it
Thanks in advance for the help.
Radiator
pcm which i have
Vs Cam Duh..- check
Tensioner - Check
Ls1 retainers
42 injectors
4340 input shaft?
Harden 4th?
