rafadavidc
Oh, jeez, I hadn't thought of this. How often have you changed your oil? You said you've owned this car since new - have you taken care of the oil? Because the timing chain is one of the first components of an engine to complain about a lifetime of poopy oil. What I don't know is if a stretchy chain will advance or retard the timing. Someone else will have to chime in on that one.Well I own a GTP and know these things have coils but back in the day when it was distributors and points pinging was from the timing when you was advancing until it pinged then turned back to retard it. How many miles are on your car? Do you get on it at all? have you ever checked the timing chain for stretch or the dampener? Like I said before not sure but pinging to me is a timing issue if your timing is off do to wear it would ping and possibly overheat under heavy load as it is working harder and having a timing issue.
Still primarily a coolant issue, though.
