mine does this, i found that if you close the visor while closing the sunroof from fully open it will slide easily into place.
I cant stand being in a car with the sunroof visor closed. But thats just me.
Thanks so much! Your advice saved me a heck of a lot of time and/or expense.What has happened is there is two plastic caps on the end of the slide rail for the visor near the back of the headliner. They are rivoted in one place and if you put too much force into opening it they will snap off. Then the end of the sun visor has a lip on it will catch and you wont be able to get it back up. You can try to push up on the headliner near the back of the car maybe 2/3 the way back while you pull the slide closed and dont push it all the way back next time.
^^^:th_scratchhead:? thats helpful
Apologize for the bump...
My visor is stuck back, but not back so far that the handle isn't visible. Tried pushing up 2/3 the way back and pulling forward but doesn't seem to work.
Is removing the headliner and doing it by hand a viable option?
