Thread: Roar in front end
Results 1 to 11 of 11
  1. #1 Roar in front end
    SE Level Member SilvrGrandPrixGT's Avatar
    Nov 2009
    Indiana
    I'm having some problems with my 01 Grand Prix. The front end is roaring when I get up to about 20mph it will do it from here on out to about 70, then the noises of the highway and such drown it out. It's not really a vibration because you can't feel it in the steering wheel or anything. The best way to put it is...it sounds like I'm driving down the road in a jacked up truck with super swampers; that annoying little hummmmmmmm!! I think the tires are ok. That's what I thought it was at first but I had them checked and rotated and they're fine. Let me know what you think!
  2. #2 Re: Roar in front end
    PA
    My first thought would be a wheel bearing.
    2001 GSE
  3. #3 Re: Roar in front end
    Nov 2009
    Indiana
    I jacked the car up to see if the wheel had any play in it and it didn't at all. I tried to move it side to side and up and down, but it had no play at all. If it was a wheel bearing, wouldn't it move around some? At least that was the case when I had a 00 GMC 1500 4x4.
  4. #4 Re: Roar in front end
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    I'm pretty sure its going to be your wheel bearing. If you leave it for much longer its going to start to have some play in it.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Roar in front end
    Wausau, WI
    Quote Originally Posted by SilvrGrandPrixGT View Post
    not necessarily. I had a wheel bearing with a hum that lasted for months and still felt OK with no play in it. I replaced the wheel bearing and noise gone...
  6. #6 Re: Roar in front end
    GT Level Member DBGP's Avatar
    Vancouver, BC, Canada
    how much would new bearings be you think? cause i think i have the same issue
  7. #7 Re: Roar in front end
    SE Level Member Feather Head's Avatar
    Wausau
    From NAPA with my discount the normal one was $100 and the ultimate was like $190 if i remember right.
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  8. #8 Re: Roar in front end
    Nov 2009
    Indiana
    Thank you all for confirming what I had thought already. Hopefully I'll have the time to replace it soon and see if that helps.
  9. #9 Re: Roar in front end
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    at orileys you can get them for like 150 for the good ones (but i get a friends discount)
  10. #10 Re: Roar in front end
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    RockAuto Auto Parts has them cheap. I got the timken autozone sells for $200 for $106 there.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  11. #11 Re: Roar in front end
    Wooster, Ohio
    timken or skf is the way to go, make sure there lifetime warr and cover the sensors as well as the bearings
  1. Rear End Roar
    By bshinos in forum General Tech Discussion
    Last Post: 11-30-2010, 01:52 PM
  2. Front end
    By Independentvice in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2009, 01:11 AM
  3. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
  4. roar in front end of my 93 gp 3.4
    By lookout in forum 3.4L V6 (LQ1) DOHC
    Last Post: 01-10-2009, 06:17 PM
  5. GXP front end?
    By shotgundust in forum Visual/Body Modifications
    Last Post: 04-06-2008, 01:02 AM
