Iron Indian
Just wondering? My white car has the original ones at 170,000 miles. Wondering if I should put in a different set before I start racing the car on slicks.........
ANyone else?
I am on stockers and allmost 1sec in the 1/4 fasteryour ok.
If you still have your stock ones on the car, and there is no issue with them - LEAVE THEM ALONE. Stock ones will last just fine, until the boots crack. I have not had any luck with aftermarket ones, including ZZP 'Stage I' or whatever. Those were good for about 12 months. Also, when you do need to replace one, buy one from your local part store that has a lifetime warranty. Be prepared to get good at axle replacements once your stockers finally go, but like, I said, I would hold out as long as you can.
