Thread: Some more top swap questions! Yay!
Page 70 of 71 FirstFirst ... 206068697071 LastLast
Results 1,381 to 1,400 of 1411
  1. #1381 Re: Some more top swap questions! Yay!
    nothing really, i got them before i had a tuner, they took 5º of kr out of the stock tune.
    how she running these days?
  2. #1382 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Shes running strong 0kr through the rpms. Still having the flash kr problem so i just havent been mashing on it. I just made a thread asking for some knowledge. I just purchased those yt 1.9s so i cant wait to get those in. Im hopefull ill be able to install those and add a couple degrees of timing to my tune.
    Sent from my LG-D851 using Tapatalk
  3. #1383 Re: Some more top swap questions! Yay!
    im willing to bet your maxed out on timing. even with rockers.
    the timing i gave you is what i was running when i had the rockers heads and stock pulley. the rockers will just let it flow better and you'll feel some power gains from them, not a ton tho.
  4. #1384 Re: Some more top swap questions! Yay!
    Oct 2015
    Well if it killed kr on your build and im running 0kr on my build wouldnt i be able to add timing hypothetically?
  5. #1385 Re: Some more top swap questions! Yay!
    no bone stock ont he l67, they were my very first mod. i had 8 kr before the rockers, they killed 5 off, a simple u band delete killed off the last 3. then i got a tuner, headers and a 3.4....
    blew that up^^^^
    then did the ported heads, rockers on the top swap. then a 1000 miles later i added the ic injectors and bought a 5 pack of pulleys, 2.8 up to a 3.4.
    rockers add some power, but it not like you added a ic. cant hurt to play with the timing. but id think your stuck where your at for timing.
  6. #1386 Re: Some more top swap questions! Yay!
    Oct 2015
    Okayy. Howd you blow the motor on a 3.4 with headers?
  7. #1387 Re: Some more top swap questions! Yay!
    fuel pump took a crap. i was at the top of second gear wot, when it shifted, it made sounds you never want to hear, i knew it was f ed up asap. bout a mile later i got a cyd 3 misfire code. found it smashed in. and that means chip showed up to the party.
    still dint know the pump was failing, and lucky it took a full proper crap soon after the engine swap.
    funny part is the top swapped engine was about done and was planned to be swapped in 2 days, only the plan was to have a running spare engine lol guess not.
  8. #1388 Re: Some more top swap questions! Yay!
    Oct 2015
    Well atleast you were ready to go haha. Hey thise yt just use regular reusable rocker bolts right?
  9. #1389 Re: Some more top swap questions! Yay!
    yup. tq'ed to 25 fp
  10. #1390 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty
  11. #1391 Re: Some more top swap questions! Yay!
    Oct 2015
    Hey scotty or anyone! I should have my 1.9 roller rockers tomorow and had a question. I doubt that the guy that shipped them have them labeled for which rocker went with what pushrod and such so should i use some arp assembly lube or since they only have 6k miles on them does it even matter.
  12. #1392 Re: Some more top swap questions! Yay!
    mine were mixed up too, dont really matter. but its nice to keep em mated up. i did that when i did the engine swap, made a cardboard tray to hold everything in place.
    id put a smear of grease on the tip of the push rod, and the top of the valve stem where the roller goes, nothing thick, just a smear to lube it while its on its first start up.
  13. #1393 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok thanks scotty!
  14. #1394 Re: Some more top swap questions! Yay!
    I'm just wondering...
    how in the hell is a top swap thread 70~ pages...and why is it a sticky...I'm not going through it.
  15. #1395 Re: Some more top swap questions! Yay!
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by blueguy View Post
    Because it literally goes through any question possible. There should be no more threads after this.
  16. #1396 Re: Some more top swap questions! Yay!
    Back when people actually read things; there was already a lengthy sticky on the subject: http://www.grandprixforums.net/threa...s-of-3800-Info
    Edit: no one is even going to come close to reading 70 pages. No one even opens a thread and reads the first page. Bravo for everyone that participated...but that's overkill.
  17. #1397 Re: Some more top swap questions! Yay!
    Apr 2015
    And this went more into detail about parts and stuff.
  18. #1398 Re: Some more top swap questions! Yay!
    Oct 2015
    So people will stop asking, this is the point of this thread. I never would have been able to do this without this thread. The problem is theres a lot of smart people on here but also a few people that post that dont know what there talking about and give miss information. So this thread clears up all the questions that might be confusing for others like they were for me.
  19. #1399 Re: Some more top swap questions! Yay!
    Nov 2012
    Madison
    another question.....
    is the foil to prevent raDiation?..................
  20. #1400 Re: Some more top swap questions! Yay!
    Oct 2015
    Yes!
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
