Thread: Squishy brakes after replacing them. Replace boots and pin covers?
Results 1 to 5 of 5
  1. #1 Squishy brakes after replacing them. Replace boots and pin covers?
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I replaced my front brakes a while ago. The brakes had about 40k, so they did have to be replaced. While removing the caliper bolt, I pulled out one of the rubber slides - NOT the boot. Every other time I've changed the brakes, that slide never came out. I've always used plenty of grease on the changes, and the caliper bolts came out with some grease still on them. I've also never replaced the rubber components.
    Anyway, since I was able to put the old rubber slide back in by pushing it in with a screwdriver, my brakes have been pretty squishy. I had the brake fluid replaced as well, and that didn't improve it.
    Would that rubber slide make that much of a difference? A new set of rubber components is pretty cheap, so I'll buy them and spend an hour swapping them if that will fix it.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Squishy brakes after replacing them. Replace boots and pin covers?
    mi
    Bleed them.
    I'm sure you know that slide cover doesn't do anything but keep slides clean.
  3. #3 Re: Squishy brakes after replacing them. Replace boots and pin covers?
    ^^^This. You might have a very slow leak somewhere as well
  4. #4 Re: Squishy brakes after replacing them. Replace boots and pin covers?
    check the back brakes, low back pads can give you low pedal feel. and your brake lines for swelling. rubber gets old and weak, and a bubble can form.
  5. #5 Re: Squishy brakes after replacing them. Replace boots and pin covers?
    Feb 2008
    Cumming GA
    I had a shop do the brake fluid, after the fronts were changed. I was going to put off the rears for another month, but that's probably the issue. The fronts were worn down past the slot, and I'm sure the rears are about the same.
  1. Changing Axle Boots?
    By Points70 in forum General Tech Discussion
    Last Post: 01-30-2012, 08:54 AM
  2. brakes staying squishy after 12in U.G. and rebuilt rears
    By Regalgs98 in forum Brakes/Suspension/Chassis
    Last Post: 11-10-2011, 09:32 AM
  3. Replace Brakes and Rotors But still have a rubbing Noise.
    By rollin77 in forum Brakes/Suspension/Chassis
    Last Post: 11-24-2009, 02:02 AM
  4. replacing CPS, can/ should I replace front seal then?
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 08:45 AM
  5. Tired of IT - CV Boots/Axels
    By japslpr in forum Brakes/Suspension/Chassis
    Last Post: 02-10-2008, 12:20 PM
