Thread: USB Ports next to heated seat switch
Results 1 to 9 of 9
  1. #1 USB Ports next to heated seat switch
    SE Level Member Biohazard's Avatar
    May 2013
    Lincoln, NE
    I installed a dual USB port next to my heated seat switch, thought I could use up some of that large empty space. It was pretty easy, I took apart one of those cigarette lighter USB deals, cut a hole into the plastic, and mounted it from behind, tapping into the cigarette lighter wires.
    It could be cleaned up, I'm working up some ideas. I was going to use the plastic plate from the source of the USB's but that makes it too deep.
  2. #2 Re: USB Ports next to heated seat switch
    Cambridge, Ontario Canada
    Good
    2005 E55 - stock
  3. #3 Re: USB Ports next to heated seat switch
    Looks good.
    This is connected to your radio or just a way to charge stuff? If it's just charging, having it straight down allows things to fall into it. If there's a cover on the piece you took it out of..maybe try and incorporate that in.
  4. #4 Re: USB Ports next to heated seat switch
    May 2013
    Lincoln, NE
    Just for charging. And thanks for the tip about stuff falling in, I didn't think about that. I'll figure some sort of cover out.
  5. #5 Re: USB Ports next to heated seat switch
    It's the same as when someone says their OBDII port ain't working.. First thing you tell them is..take the penny outta your cigarette lighter and fix the fuxe.
  6. #6 Re: USB Ports next to heated seat switch
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Quote Originally Posted by Biohazard View Post
    I installed a dual USB port next to my heated seat switch, thought I could use up some of that large empty space. It was pretty easy, I took apart one of those cigarette lighter USB deals, cut a hole into the plastic, and mounted it from behind, tapping into the cigarette lighter wires.It could be cleaned up, I'm working up some ideas. I was going to use the plastic plate from the source of the USB's but that makes it too deep.
    This is a great idea, both as a charge port or even as someone else asked, a USB connection to a headunit. Now, I don't have the heated seat option, if I got the heated seat plate, would it fit where I have a little cubby hole?
  7. #7 Re: USB Ports next to heated seat switch
    May 2013
    Lincoln, NE
    As long as there is room to mount the usb ports (which isn't that big) I don't see why not. Here's how I did mine, I took the USB portion out of one of these cheap car chargers, cut a hole into the heated seat plate, and glued it in. Then wired it up to the wires going to the cigarette lighter.
  8. #8 Re: USB Ports next to heated seat switch
    Mar 2013
    Manitoba, Canada
    Looks good. Do you have a picture of the finished product in your vehicle?
  9. #9 Re: USB Ports next to heated seat switch
    May 2013
    Lincoln, NE
    That is the one that's next to the heated seat switch. Pics in first post.
  1. Shortened Dog Bones, speedometer, and more!
    By cmal37 in forum For Sale - Parts
    Last Post: 03-26-2014, 08:43 PM
  2. heated seat switch help
    By Logan541 in forum General Tech Discussion
    Last Post: 09-01-2012, 10:28 AM
  3. Heated Seat Switch
    By Iceman6669 in forum General Tech Discussion
    Last Post: 04-14-2012, 10:20 AM
  4. Heated Seat Switch Illumination
    By SliceTheRice in forum General Tech Discussion
    Last Post: 05-10-2010, 11:49 AM
