Thread: Supercharger seized up wont turn any fix?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    I have seen a few of them locked up and it was a shredded coupler that was jammed up in the gears and smoked the belt. It took quite a bit of working it to get it free again. The other was the cage on a meedle bearing and I ended up pressing the bearings out with the rotor by putting the bolts back in without the snout and pressing the bearings with a piece of 1" square stock and a pair of sockets Gen 5 will be different since there's no real access to the bearings although you may be able to drill a hole and tap it 1/4-28 then install Zerk fittings and push it out using hydraulic pressure. The other one was FOD and it ingested a #10 screw (at least that's what it looked like). The Gen 5 the cartridge actually slides almost an inch into the case so they are a lot harder to get apart then a Gen 3. If you take a 3/4" dowel and pass it through to the bearing plate you may be able to knock it out enough to get at the edges. Use a plastic or wood rod to go around the case to get it out then. You will damage several pieces of wood or plastic, but better that than the case. If you try to use Aluminum, Brass or Copper it's too hard. You need something softer than the aluminum Delrin is pretty good for doing this. Just go slow and look after every hit if you get it cocked in there it will be even more difficult to get out.
    Jeff
    Last edited by J57ltr; 07-21-2015 at 06:46 PM. Reason: Didn't specify needle bearing.
  2. #22 Re: Supercharger seized up wont turn any fix?
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    short simple version ^^^ junk it
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  3. #23 Re: Supercharger seized up wont turn any fix?
    Nov 2013
    United States
    If you're going to junk it I'll snag it off ya. I'm in MD too so we could meet somewhere.
  4. #24 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    Oh almost forgot the guy running a top speed run and the rotors swelled and ended up seizing to the case after he shut it down. And also saw a couple of guys that had leaking cases and the cartridge bearings seized after they ran them hard without any fluid in them. Hell take it apart and see it can't hurt. if you want I could make a cutaway model of it if all is lost. I bet I can get it apart though.
    Jeff
  5. #25 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    Post some pics of the blower outlet.
  6. #26 Re: Supercharger seized up wont turn any fix?
    Jeff is talking about this.. However there is not really room on the Gen V. I believe you would want a blind pilot bearing puller to do the rear case bearings on a Gen V.
    Find these holes (Gen 3)
  7. #27 Re: Supercharger seized up wont turn any fix?
    For anyone wondering.. yes.. I do have pictures of damn near everything.
  8. #28 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by J57ltr View Post
    Tomorrow i will be by the blower to take pics been working and being daddy really hope to save it .. Talked to the Guy yesterday told me he hasnt done maintenance on the blower.. No new coupler... No fresh oil.. So .. He hasnt helped the situation also like to note that i saw oil dripping out of the drain hole slowly out kg the blower when i looked closely
  9. #29 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    Bill,
    I know the bearing is open, but is there enough room to get behind the bearing to try? I'm not looking to get the bearing out but if the seal is good then he may be able to push the bearing and shafts or just the shafts out if he can't get a dowel in there to smack it hard enough to move the rotorpack.
    jayroca,
    Well, it's always worth a try.
  10. #30 Re: Supercharger seized up wont turn any fix?
    Jeff.. we need a picture of a Gen V upside down. I know a guy. Hang on...I'll ask him to post a pic. IIRC though there isn't room to drill/tap w/o nicking the bearing and once you pop a hole in the back of the bearing cap.. you ain't pushing nada.
    Hey Jeff buddy.. can you get a picture of the underside of a Gen V, for this guy Jeff above who is asking about it?
    hahahahahaha
  11. #31 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    Sure, think this is the best angle I have on the phone right now:
  12. #32 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    I was gonna work on it but i havent had to the time to break it down that one torq bit bolt is giving me a little issues Bill though lol
  13. #33 Re: Supercharger seized up wont turn any fix?
    take a chisel and a hammer to the side of the bolt. it will crack free.
  14. #34 Re: Supercharger seized up wont turn any fix?
    Banned
    Jan 2013
    maryland
    As much as i wanted to save this blower Dont have time to tear into it and figure the loose ends but if anybody that lives in maryland area wants a Gen V to work on lmk and we can work somthing out if not i will take it to the scrapyard and and get some gas money lol
  15. #35 Re: Supercharger seized up wont turn any fix?
    GXP Level Member
    Mar 2015
    Tomball
    Send it to me I'll get it apart for you.
  1. wont turn over...
    By dklonewolf in forum General Grand Prix Discussion
    Last Post: 09-15-2013, 02:34 PM
  2. Key wont turn
    By RedGrandprixgt53 in forum General Tech Discussion
    Last Post: 12-02-2011, 04:27 PM
  3. TCS wont turn on
    By jmalin72207 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:19 AM
  4. please help, air wont turn off
    By red60degreeGP in forum General Tech Discussion
    Last Post: 04-23-2009, 06:26 PM
  5. My Car wont Turn off !!!
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-15-2008, 01:02 AM
