Thread: Spark plug correct gapping
Results 1 to 6 of 6
  1. #1 Spark plug correct gapping
    Banned
    Jan 2013
    maryland
    Ok guys picked up some fresh Autolites 104's to get my motor running and want to know what is the proper gapping for these plugs mods are as follows if that helps:
    XP Cam
    Stage 3 P&P Heads
    130# Springs
    SD Headers
    3.2 pulley
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Spark plug correct gapping
  3. #3 Re: Spark plug correct gapping
    Jul 2012
    Clayton,NC
    I run my 103's at 35 because it was showing I was getting blowout on the dyno. I would say start around 40 to 45 and then you can tighten it up if you start to get blowout.
    98 gtp- cammed intercooled slowness
  4. #4 Re: Spark plug correct gapping
    Banned
    Jan 2013
    maryland
    Aren't 103's to cold? Dsmuts I'm leaning to .055 but I'ma do 40 as well
  5. #5 Re: Spark plug correct gapping
    104's is what I'd run. I'm running 104's @ .055 right now. I have about 15k on them right now
  6. #6 Re: Spark plug correct gapping
    Aug 2013
    Ontario
    I run my 104's at .045.
  1. spark plugs & gapping
    By drewzilla03 in forum 04+ Specifics
    Last Post: 04-02-2013, 08:52 PM
  2. Spark plug gapping
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2012, 05:12 PM
  3. correct spark plugs/wire set
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2012, 03:40 PM
  4. Plug Gapping
    By sinceregtp in forum General Tech Discussion
    Last Post: 10-11-2009, 12:04 PM
  5. spark plug gapping?
    By s1795so2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 10:15 AM
