Thread: Cooling troubles on Grand Prix
Results 1 to 7 of 7
  1. #1 Cooling troubles on Grand Prix
    Nov 2009
    SW MN
    I have a 2006 GP GT. When the ambient temp is warm and the car is in traffic it will get hot. When the ambient temp is cold the car will not reach operating temperature while driving.
    My first instinct was that the thermostat was bad. So I replaced the thermostat and flushed the coolant. This had no effect.
    When hot the fans kick on when they are supposed to. The car has a new radiator cap too. No leaks and no issues with pressure testing.
    Took to the dealer thinking it was under warranty. They couldn't find anything actually wrong with it because they couldn't diagnose it so my warranty did not pay them I needed to.
    Any thoughts or suggestions from previous experiences would be great!
  2. #2 Re: Cooling troubles on Grand Prix
    Guam
    The car has two stage fan control. Possibly there is an issue there. Also, make sure there is coolant in the bottle. If not, it will be slow to warm up. Here is the GM serv manual diagnosis for the fans. Lengthy, but this is what can be checked for the fans. The links will not work, so don't try to click on them.
    Did you perform the Diagnostic System Check - Vehicle?
    Go to Step 2
    Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
    1. <LI type=1>Install a scan tool. <LI type=1>Turn ON the ignition, with the engine OFF.
    2. With a scan tool, command the Fans Low Speed ON and OFF.
    Do the low speed engine cooling fans turn ON and OFF with each command?
    Go to Step 3
    Go to Step 4
    Important:
    A 3-second delay occurs before the powertrain control module (PCM) changes the cooling fan speed.
    With a scan tool, command the Fans High Speed ON and OFF.
    Do the high speed engine cooling fans turn ON and OFF with each command?
    Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
    Go to Step 12
    1. Important
      Do NOT remove the 20-amp fused jumper wire connected during this step. Use a second 20-amp fused jumper wire while performing the following steps.
      <LI type=1>Remove the fan 1 relay.
    2. Connect a 20-amp fused jumper between the battery positive switch side voltage circuit and the fan motor supply voltage circuit of the cooling fan 1 relay.
    Do both cooling fans operate in low speed?
    Go to Step 22
    Go to Step 5
    1. <LI type=1>Disconnect the fan 2 relay.
    2. Connect the second 20-amp fused jumper between the cooling fan low reference circuit and the cooling fan motor supply voltage circuit of the fan 2 relay.
    Go to Step 23
    Go to Step 6
    6
    Connect the second 20-amp fused jumper between the battery positive voltage circuit and the cooling fan motor supply voltage circuit of the fan 2 relay.
    Does the right cooling fan operate in high speed?
    Go to Step 9
    Go to Step 7
    7
    1. <LI type=1>Install the fan 2 relay. <LI type=1>Disconnect the right cooling fan electrical connector.
    2. Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit to the ground circuit of the right cooling fan electrical connector.
    Does the left cooling fan operate in high speed?
    Go to Step 25
    Go to Step 8
    8
    Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit of the right cooling fan electrical connector to a good ground.
    Go to Step 29
    Go to Step 30
    9
    1. <LI type=1>Install the fan 2 relay. <LI type=1>Disconnect the left cooling fan electrical connector.
    2. Connect the second 20-amp fused jumper wire from the cooling fan motor supply voltage circuit to the cooling fan low reference circuit of the left cooling fan electrical connector.
    Go to Step 26
    Go to Step 10
    10
    Connect the second 20-amp fused jumper wire from the coil side battery positive voltage circuit to the cooling fan low reference circuit of the cooling fan electrical connector.
    Go to Step 11
    Go to Step 31
    11
    Probe the battery positive voltage circuit on the switch side of the fan 1 relay with a test lamp that is connected to a good ground.
    Does the test lamp illuminate?
    Go to Step 27
    Go to Step 32
    12
    Is the right cooling fan operating properly in high speed?
    Go to Step 19
    Go to Step 13
    13
    1. <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the fan 3 relay. <LI type=1>Turn ON the ignition, with the engine OFF. <LI type=1>Connect a test lamp between the high speed cooling fan relay control circuit and the battery positive voltage circuit on the coil side of the fan 3 relay.
    2. With a scan tool command the High Speed Fans ON and OFF.
    Does the test lamp turn ON and OFF with each command?
    Go to Step 15
    Go to Step 14
    14
    Probe the battery positive voltage circuit on the coil side of the fan 3 relay with a test lamp that is connected to a good ground.
    Go to Step 34
    Go to Step 33
    15
    Install a 20-amp fused jumper between the battery positive voltage circuit on the switch side of the fan 3 relay and the cooling fan motor supply voltage circuit.
    Go to Step 24
    Go to Step 16
    16
    Probe the battery positive voltage circuit on the switch side of the fan 3 relay with a test lamp connected to a good ground.
    Go to Step 17
    Go to Step 33
    17
    1. <LI type=1>With the 20-amp fused jumper still installed. <LI type=1>Disconnect the right cooling fan electrical connector.
    2. Connect a test lamp from the cooling fan motor supply voltage circuit to the ground circuit of the right cooling fan electrical connector.
    Go to Step 25
    Go to Step 18
    18
    Probe the cooling fan motor supply voltage circuit of the right cooling fan electrical connector with a test lamp that is connected to a good ground.
    Go to Step 29
    Go to Step 30
    19
    1. <LI type=1>Turn OFF the ignition. <LI type=1>Disconnect the fan 2 relay. <LI type=1>Turn ON the ignition, with the engine OFF. <LI type=1>Connect a 20-amp fused jumper between the cooling fan low reference circuit and the ground circuit of the fan 2 relay.
    2. With a scan tool command the Fans High Speed ON and OFF.
    Go to Step 20
    Go to Step 28
    20
    1. <LI type=1>Connect a test lamp between the high speed cooling fan relay control circuit of the fan 2 relay and the battery positive voltage circuit of the fan 2 relay.
    Go to Step 23
    Go to Step 21
    Probe the battery positive voltage circuit of the fan 2 relay with a test lamp that is connected to a good ground.
    Go to Step 34
    Go to Step 33
    22
    Inspect for poor connections at the fan 1 relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
    Did you find and correct the condition?
    Go to Step 40
    Go to Step 35
    23
    Inspect for poor connections at the fan 2 relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
    Go to Step 40
    Go to Step 36
    24
    Inspect for poor connections at the fan 3 relay. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
    Go to Step 40
    Go to Step 37
    25
    Inspect for poor connections at the harness connector of the right cooling fan. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
    Go to Step 40
    Go to Step 38
    26
    Inspect for poor connections at the harness connector of the left cooling fan. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
    Go to Step 40
    Go to Step 39
    27
    Repair the left cooling fan motor supply voltage circuit for an open. Refer to Wiring Repairs in Wiring Systems.
    Is the repair complete?
    Go to Step 40
    28
    Repair the left cooling fan ground circuit for an open. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 40
    29
    Repair the right cooling fan ground circuit for an open. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 40
    30
    Repair the right cooling fan motor supply voltage circuit for an open. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 40
    31
    Repair the left cooling fan low reference circuit for a short to ground or an open. Refer to Wiring Repairs in Wiring Systems.
    Go to Step 40
    32
    Repair the fan 1 relay battery positive voltage circuit for an open.
    Go to Step 40
    33
    Repair the battery positive voltage circuit for the fan 2 relay and fan 3 relay for an open.
    Go to Step 40
    34
    Repair the high speed cooling fan relay control circuit for an open.
    Go to Step 40
    35
    Replace the fan 1 relay.
    Go to Step 40
    36
    Replace the fan 2 relay.
    Go to Step 40
    37
    Replace the fan 3 relay.
    Go to Step 40
    38
    Replace the right cooling fan. Refer to Cooling Fan Motor Replacement - Electric .
    Go to Step 40
    39
    Replace the left cooling fan. Refer to Cooling Fan Motor Replacement - Electric .
    Go to Step 40
    40
    Operate the system in order to verify the repair.
    Did you correct the condition?
  3. #3 Re: Cooling troubles on Grand Prix
    Nov 2009
    SW MN
    Thanks. No joke about that being lengthy. I will need to set aside some time to go through that on a weekend.
    I should add that the car was perfect until one day a couple months ago this all started. I can pinpoint the date. I had driven the car for 95 miles in 95 degree heat with the air going full. I had the cruise set at about 82. When I got into traffic the gage was very quick to move up. The car had burned all the antifreeze out of the reservoir during that trip. It had just been serviced 2 days earlier and checked at that time.
  4. #4 Re: Cooling troubles on Grand Prix
    PA
    Quote Originally Posted by wkjeep View Post
    My first thought would be if you bled it correctly. I know the problem started before that. But a lot of times people will notice the car overheating due to coolant being low. Then then will start changing things and not bleed it correctly, so they either get too much air trapped in the system, or it will still be low on fluid.
    When the car is cool, pull the radiator cap and confirm that there is coolant to the very top of the radiator.
    2001 GSE
  5. #5 Re: Cooling troubles on Grand Prix
    Nov 2009
    SW MN
    The system has been bled by me and the dealership for a total of about 6 times. There is no air left in it to my knowledge.
    I thought that would be the problem too after the thermostat first being changed.
  6. #6 Re: Cooling troubles on Grand Prix
    Apr 2012
    sw
    Is there a supercharger on it? I have a compg and it runs very hot. Not enough cooling in traffic with the air on, however it does ot over heat. i make sure the over flow bottle is full on trips.
  7. #7 Re: Cooling troubles on Grand Prix
    St. Louis
    Join Date11-03-2009
    Last Activity
    09-07-2011
    Don't think the OP is going to answer, especially from a 3 year old post.
    BTW, these cars run hot naturally. If it's not overheating then its fine.
  1. Grand prix GT side skirts on 97 Grand Prix SE
    By Carnes97SE in forum How To Write-Ups/Tech Tips
    Last Post: 11-17-2013, 05:17 PM
  2. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  3. Electrical Troubles
    By Orozco in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2009, 12:00 AM
  4. Need some help with amp and sub troubles
    By Thunderturd in forum Audio, Security & Visual Electronics
    Last Post: 08-20-2009, 02:51 AM
  5. downpipe troubles, advice?
    By Jakegday in forum General Tech Discussion
    Last Post: 04-29-2009, 06:26 PM
