Thread: Spectre cone filter install help
Results 1 to 19 of 19
  1. #1 Spectre cone filter install help
    GTX Level Member SF9777's Avatar
    Jan 2012
    Anaheim, Ca
    My bro and i are going to install a spectre cone filter into our stock house at the end of the MAF. but there is another hose connected to the air box which some people have said is for emissions. what do we do with it and where can we have this installed to? Going to install it tomorrow so need help.
    Heres a pic its that small hose connected to the right of the MAF there in the Pic
  2. #2 Re: Spectre cone filter install help
    thats the air pump hose it looks like.
    CA emissions only type junk.
  3. #3 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    So what do we do with it, how do we get it connected to the cone filter when we install it?
  4. #4 Re: Spectre cone filter install help
    Your going to have to maybe extend the cone out some with a rubber coupler and cut a hole in it and put that hose in there and make sure its tight.
  5. #5 Re: Spectre cone filter install help
    GTP Level Member
    Nov 2011
    Kansas
    I dont think my car had that.. .interesting.
  6. #6 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    Hmmm, i friend of mine suggested a 3" pcv coupler, could that work and what to use to tighten it? is tape too weak?
  7. #7 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by develand View Post
    is yours a base? mine is and its a 07
  8. #8 Re: Spectre cone filter install help
    Your car is a CA car, so its special and HAS to meet certain emission standards that his does not.
    And I drawed you a cool pic of my awesome idea.
  9. #9 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    Stupied Ca standards, well thats Cali for ya. Very nice artistic skills, and yes i had something similar to that in my head and i think i just might do that. Thanks and it is a "Kewl Idea" indeed, how do you suppose we tighten it with?
  10. #10 Re: Spectre cone filter install help
    Id fine some hose clamps or something along those lines to make the coupler to the maf work and to the filter.
    ANd then maybe cut the hole in the rubber coupler for the air pump hose and use some rubber cement to glue a smaller rubber piece to it and slide the air pump hose over and clamp it. Im not sure if it would work, but its a idea that might work.
  11. #11 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    I think it may work like that OR we could take the hose threw the hole and tape it or something, got any other Kewl ideas? lol ill be back in like a hour to this thread. Thanks for the help btw
  12. #12 Re: Spectre cone filter install help
    Jul 2008
    Tampa, FL
    stupid cali emissions. that's why i still have illinois plates.
  13. #13 Re: Spectre cone filter install help
    Dec 2008
    Lawndale, CA
    You can just get a small fiter and clamp it on the hose. F body guys do it all the time.
  14. #14 Re: Spectre cone filter install help
    Jan 2012
    Anaheim, Ca
    Quote Originally Posted by The Guz View Post
    I think i might just do that, that OR put on a pcv coupler, either way we will figure it out. if got any ?s i let you guys know and thanks for help.
  15. #15 Re: Spectre cone filter install help
    Portland Oregon
    Or you chould just zip tie the hose somewhere. It just pumps air into the exhaust for like 5 seconds at startup. It's literally useless
  16. #16 Re: Spectre cone filter install help
  17. #17 Re: Spectre cone filter install help
    Picassodeathpunch
    Anyone else think his intake looks like a donkey leg?
  18. #18 Re: Spectre cone filter install help
    I live here. TLSheff's Avatar
    don't forget the 2nd... STOP... hammertime!
  19. #19 Re: Spectre cone filter install help UPDATED FILTER INSTALLED
    Jan 2012
    Anaheim, Ca
    I got it installed finally!!! Got a pcv coupler and a pipe and hooked them together to fit the MAF and the pipe thing came with a small third hole and a little u bend pipe to connect the stupid hose for the stupid cali emissions and connected the other side to the filter. now the filter touches a little part of the roof and is at the back behind the headlight that has a hole there. we used zip tie to hold it still and up on the bar there and zip tied the pcm down too. it now makes a rumble noise now that sounds cool like a muscle car sound, is that good?
    EDIT: the zip tie there that is clamping the maf to the pipe there is gone and we put acutal clamps there since it came off when we looked at when we came back from driving. so now it should be stuck on good (we use the same clamp thats clamping the filter there the silver one).
  1. 6.75" spectre filter
    By BlackGT97 in forum General Tech Discussion
    Last Post: 07-27-2011, 07:00 PM
  2. Spectre air filter or no?
    By str3etgl0w in forum General Tech Discussion
    Last Post: 06-28-2011, 05:58 PM
  3. How to install AEM cone filter/cold air intake
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 04-19-2011, 06:46 PM
  4. spectre open cone IAT placement.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-16-2010, 07:47 PM
