Thread: Crazy Taz and his wire tuck.
Page 17 of 20 FirstFirst ... 71516171819 ... LastLast
Results 321 to 340 of 384
  1. #321 Re: Crazy Taz and his wire tuck.
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    yea it took me a few mins to find the balls to start it up but I did and it runs fine I let it idle for 10 mins and saw no smoke anywhere
    one of my brand new hids didn't seem to work tho... hopefuly I just forgot to plug in a wire on that side but idk Ill just drive with the brights on
  2. #322 Re: Crazy Taz and his wire tuck.
    congrats! i knew it would work!
  3. #323 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    well hopefully at work I don't see my car on fire when i go on break lol
    but I felt up and down all the wires and didn't feel any hot spots and smelt nor saw any smoke so I think it's good
  4. #324 Re: Crazy Taz and his wire tuck.
    some headers come very close to your starter wire.
  5. #325 Re: Crazy Taz and his wire tuck.
    The parts car was ridiculously dirty but oil prevents rust right? Glad it worked out for you.
  6. #326 Re: Crazy Taz and his wire tuck.
    London Ont, Canada
    Glad to hear ya got it working!
    and a special congrats to dsmuts! Thats what a community is for!
  7. #327 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    so my lights....
    with the normal lights on only the passenger side hid comes on... with the brights on only the driver side light comes on... so do zzp lights blow that bad or did I not plug the lights in right idk I'm going to go mess with them but I kind of need lights lol my fogs are 6000k so they are bright enough to drive off of but I think thats illegal no headlights...
    ffs one thing after the other right
  8. #328 Re: Crazy Taz and his wire tuck.
    Congrats man.. glad to hear it's back to running. Kudo's on all the good work.
  9. #329 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    so I just tried driving with only the fogs... I stopped and backed up back to my driveway I couldn't see a thing... lol how do i check to see if these hids are bad I'm kinda upset about this zzp 120 bucks you send no directions and after less than 2 hours of on time they dont work? wth
  10. #330 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    put my old bulbs in idk what I'm going to do with the hid kit probablly drive all the way to zzp hq and throw it through the window...
    Drove the car around a bit wanted to make sure everything is good before I take it down to lake cumberland and all the electronics seemed to still work fine past 140 so I think its good to go : P
    Probablly change the oil and maybe do a coolant flush before I leave tomorrow... Oh and I'm missing one of my lug nuts because my dad lost one off of his car and took one from my car and said you can go to auto zone... so how long can I drive with out that lol
  11. #331 Re: Crazy Taz and his wire tuck.
    Waukesha, WI
    i wonder how much it would be to ship a lug nut in the mail lol i have a giant bag of brand new ones.
    taz atleast you didnt have crazy wire fire when you started your car up.
    when i finished my wagon i fired it up and it ran for 2min then one of the battery cables melted and started a fire, ( pontiacs great idea of runnning the wire an inch from the headers on top of the motor mount)
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  12. #332 Re: Crazy Taz and his wire tuck.
    Windsor (ON) Canada
    Taz... been watching this post for a while.. nice work on the car, plans on cleaning up the other side??
    Not thread jacking but I've had my vvme HIDs in for about 2 months, more than not only my passager side has been lighting up. Not sure whats up but your not alone lol
  13. #333 Re: Crazy Taz and his wire tuck.
    sweet deal man.
    driving on 4 lugs nutz is just as safe, aslong as they are torqued to spec
  14. #334 Re: Crazy Taz and his wire tuck.
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by Colossus View Post
    Are you guys using relay harnesses?
    And maybe this is silly but I figure I have to ask... is everything grounded properly? I've had my VVME's for over 2 months, heads and fogs, and not a single problem.
    Also try swapping just the bulbs. If you don't give the lights proper time to cool down between on and off, you'll blow em.
  15. #335 Re: Crazy Taz and his wire tuck.
    Windsor (ON) Canada
    I have a relay harness, and they've been acting retarded. Drove to the gas station (only passenger bulb would light up). turned off to fill up (about 5 minutes). when I started it back up both bulbs worked fine... wtf.
  16. #336 Re: Crazy Taz and his wire tuck.
    Nov 2008
    Waterloo, Iowa
    Listen to the ballast when they're both on, and listen again when only one lights up and see if you can hear one of the ballasts not igniting. Most ballasts at least hum on startup.
  17. #337 Re: Crazy Taz and his wire tuck.
    I've see the ability to plug into the ballast upside down and when that's the case.. the light won't work. Sometimes it's good to try and flip your connectors.
  18. #338 Re: Crazy Taz and his wire tuck.
    Nov 2008
    Waterloo, Iowa
    I don't the the VVME ballasts can be plugged in upside down. I'd have to go out and look at mine though to know for sure.
  19. #339 Re: Crazy Taz and his wire tuck.
    Yeah, they can. And if they do then they won't work...been there, done that. Which is why I pulg them in and go key on before I bolt everything in place on each headlight/foglight.
  20. #340 Re: Crazy Taz and his wire tuck.
    Dec 2010
    Ohio
    On these theres a tab on one side that the connector slides over so you know its on the right side. When I pulled the bulbs one looked like it was full of blue ink, and the other didn't, but one had some burn marks on it as well.
    I'm going to email zzp tell them that I understand they dont take returns on electrical then I'll tell them my situation and ask if they know what might be wrong with them. If they reply with that B.S. that I did somthing wrong then I'm going to reply with you didn't include any directions what so ever...
    I'd be a lot less upset If I had only paid 50-60 bucks for them but 120 bucks for something of this quality is disipointing to me. I always thought zzp did a good job with there products but now I'm starting to understand why you all hate on them so much.
  1. Where is rear defogger relay wire? (and trunk relay wire)
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 03:10 PM
  2. my wire tuck!
    By kuntzie in forum Visual/Body Modifications
    Last Post: 06-07-2011, 07:36 AM
  3. Help me my car is going crazy!!
    By csssaint12 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2011, 12:53 PM
  4. Wire tuck
    By Clar2478 in forum Visual/Body Modifications
    Last Post: 06-05-2009, 02:37 AM
  5. crazy car need some help
    By KingOfTheSouth in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2009, 12:29 AM
