ZZP power log on a turbo car?
Smokedgtp
I was thinking of maybe picking up a ZZP power log. Are these good on turbo cars? Im running a stock front mannie and a ported rear with #6 turned. Would a power log be a good idea or should I just install the ported front I have?
Thanx guys
I think you would be fine, furthermore I do believe they also have a manifold for the rear as well that is like the plog but set up for a turbo.
correct...zzp does sell a powerlog for the rear and is only available for the turbo guys...since you are going turbo'd sounds like your looking for some reasonable power down the road...just think about want you want from your car...then what you need parts wise to make it happen. that way you may be able to save yourself some money down the road.
Good info guys. Think I'm lossing power from this OEM Mannie? I was thinking a power log may even help with turbo lag. I have the ported rear now, This one ZZ Performance will not work on my CT kit b/c my waste gate goes over the stock outlet. Mine is a very modded stock rear. ZZP did do the work.
holding you back? probably not...now anyway...more mods?? maybe then
Mods are Ct turbo kit, A2A IC, 1.9 rockers, 3" mandrel exhaust, 42# injectors, DHP tuner, I have more im just drawing a blank. Im putting down 412whp so im thinking that mannie is killing me at this point. My last GTP was 390WHP and I had headers on it (but it was a GEN 5 IC set up)
o i change my last answer...I would say that it is holding you back...I figured you had a basicly stock set up just swapped for a turbo and planned on modding it further down the road.
The stock front mani is holding every 3800 back. It sucks. Get rid of it. :th_mischievious:
I thought we were talking about the rear mani...if not i would also agree to the above statement.:th_thumb-up:
He said he has a stock front mani, and a ported rear. I'd assume he's wanting to replace the front since he can't replace his rear (CT turbo kit) and hasn't done anything to the front yet.
Definitely ditch the front mani, and get a plog. I am now sure if it is still this way but they used to make a normal plog with straight primaries and a turbo plog with angled primaries. Make sure you get one with the angled primaries if you get a used one.
