ZZP downpipe
offroadfury6
not sure if in right section but thats why we got mods lol
anyways i got myself enuff cash for a DP, question is i dunno what the hell to get, i'm in-expericened with this and i dunno what options or size i need
do i need the shorty or offroad?
w/ cat?
w/ O2 sensor?
2.5, 3" ?
also note i DO have to pass emissions
what setup will give me max performance on my 06 GP?
thnx
the fine print on zzp.com
" ***IMPORTANT information concerning High Flow Catalytic converters*******
The downpipes we sell come with a Magnaflow high performance converter. It is OBD2 compliant but it is on the very edge of being so. The PO 420 code is set when the rear bank O2 sensor PCM thinks that the converter is not doing a good enough job. Because the stock cat is so thick and dense, it can still function when the tune is off or it gets old. The Magnaflow isn’t like that. An error in tuning, running too rich, having too cold of a Tstat, too cold of plugs, or an old primary O2 sensor can all affect the engine enough to set a code when using the Magnaflow cat. This code DOES NOT affect the way the car runs, it just sets an SES light. To fix it, you’ll need that code removed from the PCM, or you can run our O2 emulator(not available for ALL vehicles), or you can clear the code and try to tune the car in better to allow the cat to operate more efficiently. This is a situation in which your cars stock sensor was not designed with your performance goals in mind. Please make your purchase with the understanding that over time, an SES light could be thrown due to the reasons stated above. This is not grounds for a warranty claim, as a repair or replace of the cat/downpipe would not permanently fix the code. "
you should be fine with it. if it throws a code set the code to no report and youll never have that problem again. gotta find someone with a tuner though.
I got the 2.5 shorty last week and have had no problems at all with codes. Your gonna like the extra pep from the DP.
i have a 3" zzp downpipe on my car with the cat, its good and if your car is naturally aspirated you should get the 2.5". The 3 inch usually works good on supercharge cars. Just make sure you keep that cat. No cats= soot on your bumper, sounds too blatty, smelly (watch out for cops), and of course you wont pass emissions.
