91parkave
Well for guys with these control arms, we all know your sway bar will not be level due to the provided spherical rod bearing height, maybe if your dway has been flipped you might be able to achieve it being level. However itsnt a practical solution for everybody, but for 12 bucks and a trip to ACE hardware you can use 1/2 hook bolts that be adjusted to whatever height needed. All you need to do cut the hook portion and press it out or drill it out, and cut the thread to desired height.
