    TIPS:
ZZP Built Transmission
Status
Not open for further replies.
BoostedPontiac
Regal GS Level Member
This is basically one of the last things ive got for sale:
My ZZP Transmission. Its located in South Haven Michigan. Id really like to not ship this so it will be local pickup only right now.
This transmission held up really well with street/track use. Ive only got a few good launches on it with my turbo setup. The rest of it was DD use with all seasons. Unsure of mileage but the fluid is clean and there are no chucks or bits and pieces on the trans pan magnet.
Im not on here much any more so send any questions to my cell (269) 929-2221 and ill respond to them a lot faster than PM's I can also get you actual pictures of the trans itself.
$800 OBO
Details:
4340 Input Shaft
7/8" Chain (3.29 Gears)
Chrome Moly Pump shaft
ZZP Output Shaft
Upgraded TCC Apply
High Energy Green Bands
Hardened 4th
ZZP Aluminum Trans Pan
2500 Stall 245mm converter
Raybestos Clutches
Transgo Shift Kit
2500 stall 245mm TC
Diff Squirter
ZZP external trans pressure adjustment (basically a bolt on the front of the case that will allow you to adjust line pressure)
Painted industrial gray.
as much as I would like to drop a new trans in my car, if i installed this the car's value would double.
GLWS!
Post up some pics. Kinda interested, not sure if it'll work in my car yet. I'd probably minimum need to swap my HD diff and cover.
Guess the south will loose again.lol. good bye $4500. TEP is my only option. All my GP's are all 04+ comp g's. Wouldn't have done me a lot of good anyway. Get that trans mane!
Status
