ZZP 8 Rib SFI Balancer remove
kappa67
Hi all
I have the ZZP 8 Rib SFI Balancer.
My question:
How can I remove them if the crankshaft sensor is broken?
thanks for your answers
Not sure I follow you. If you are looking to remove the 8 rib SFI balancer to replace the crank sensor then this is what I found on ZZP's page- If You Need To Remove This The Balancer It Only Uses 2 Bolts And They Are Larger Sized Bolts Than The Stock Balancer. They Are Standard Not Metric.
Yes I red it but where are these bolts or where to put em in in the balancer?
This is the balancer:
​The holes are only holes where can I put a screw in??
