    TIPS:
zzp 1" phenolic spacer with fuel injector spacers and correct belt for sale
SgtMarshal
Active member
I'm done modding this car. I installed this spacer and had a different tune loaded at the same time. the tune was wrong and gave false signs of a vacuum leak. by the time I figured out the tune was wrong, I had taken the spacer off three times. the last time I took it off, the rtv adhered really well, and I had to chisel the supercharger off the spacer, and some damage was done. I am sure it will be fine, and will seal as long as rtv is used. a gasket probably wont vacuum seal unless the spacer is repaired.
I am including everything needed to install the spacer which is a belt sized 670, fuel injector spacers, new o rings for fuel injectors, the hardware to bolt the fuel rail down with the spacers, correct length bolts to bolt the supercharger down with the spacer. I did spill some oil on the fuel injector spacers and o rings and did my best to clean it off but there is some residual. the o rings actually need some oil for a proper seal, so there should be no issue there.
the spacer is for a gen 3
Parts are located in Kemmerer, Wyoming 83101
I am asking 250 for the whole kit shipped and paypal fees included. I am open to offers.
