zr1 or z28 carbon ceramic rotor brake swap.
carguy0119
Started this conversation on the cts-v brakes thread. Guess it's time to start my own. Quick synopsis I have one front rotor on the way from the dealer. Still working on finding part number for the caliper. This is going to be 15.5 in front carbon ceramic 2 piece rotor and rear 15.3 in 4 piston set up. This is going to be an expensive and time consuming process but i appreciate everyone's input. Went to the local parts store today and picked up some factory gtp rotors. I'm hoping to modify to create my own gtp hat section that will mate to the carbon ceramic disc ring. Once I have a working prototype I will be remachining using either stainless or aluminum. Another option I am looking at is modifying gtp wheel bearing hub assemblies to accommodate a 5x120 bolt pattern. Has anybody else had any success with this as a means of changing bolt patterns? Rotor should be here late next week. Pics coming soon!
I had Baer 2-pc rotors re-drilled to 115x5. The 120 bolt pattern is too tight to fit on 115.
Contact any company that re-drills wheels for this. It should be $50 or less per rotor.
I know I can redrill the rotor but can I redrill the wheel bearing to change the root cause of the problem to 5x120? Then I would b able to use the rotors and wheels without modification.
it was edited by a mod and now another new thread is why im asking
edit: also please use the edit button when your the last one to post it keeps threads condensed and not 30 pages of same person commenting. sorting through multiple threads and back to back comments is nonsense.
thanks.
thanks.
Sorry I am new to forums. I have no idea what u r talking about...
oh ok I think I see what u mean. Edit instead of having another post. Makes sense now. Thanks!
