Good way to fry your wiring. Let me explain.
They are not HID. Nor are they Xenon. Maybe they filled the bulb with a different gas than usual, but its still your average light bulb. Not only that, but they coated the bulb so it glows to look like a HID bulb. The problem with this is that the coating reduces light output... And to overcome that they make the bulb brighter which draws more current and fries your stock harness or damages your housing. Seen it plenty of times.
True HID... Is not just a bulb. It's a completely different method of lighting. HID = High Intensity Discharge. The bulb is filled with special gas and two electrodes. Extremely high voltage is applied to these electrodes and an arc jumps igniting the gas into a plasma, which glows. It makes very little heat output, and is very bright, but the voltage required is way more than the 12V-14V provided by your car. This requires an external ballast to be mounted which will step up the voltage for you.
Here, you can see my ballast for the driver side mounted in the fender (one for each HID bulb)...
These are my brights (which are plenty bright, just my camera with no flash didn't pick it up well)...
And the HIDs (which still the camera didn't pick up just how bright)...
And how they look...
Regular bulbs...
Here is the complete kit. Do yourself a favor and do it right. This kit cost me $150.
Hope this helps. And I hope someone learned something.
