looking to trade my turboed 98 grand prix gt for a 04+ non modded or lightly modded gt or gtp grand prix
a little about my car
98 gt
2008 L26 engine aprox 42k miles
Cartuning Turbo kit with large intercooler (specs on this easily looked up and sells for over 3800.00 new)
turbonetics blow off valve in place of the cartuning one
60# injectors
tuned
aem wideband
3 gauge pillar boost,oil pressure and air fuel
has 18 inch rims and also have stock honeycomb rims also
i have a set of low mileage ported polished heads that also go with the car
also have comp cams push rods
few other odds and ends
the car itselfe has 154k
looks pretty decent has 1 small rust spot below the fuel door
Gen 1 spoiler everyone wants
2 door of course
new wheel bearings
new battery
The car laid down 319whp on the dyno with 42lb injectors it was running lean at that time so the injectors and fuel pump were upgraded and retuned. On the way to the dyno the car blew the transmission so i am building that now to install. here is the list of parts im putting into the built trans
Hardend 4th gear hub
300m input shaft
raybestos red clutches
full rebuild kit
2500 stall converter new
shift-go shift kit
sonnex fix kit for valve body
B@M trick shift Synthetic fluid will be used
New Gemini chains
HD Diff from GTP
3.29 Gears
the guy building the transmission as built allot of race transmissions for me and ive never had a problem with 1 they generaly outlast the car
if you have any questions about it pm me i can text many pics of the car also any info about a car you would want to trade would be appreciated
98 gt
60# injectors
tuned
aem wideband
2 door of course
new wheel bearings
new battery
300m input shaft
full rebuild kit
shift-go shift kit
New Gemini chains
HD Diff from GTP
3.29 Gears
