wtf cam?
kuntzie
so what the helck kind of cam is this.. i could not find anything to close to these numbers on zzp
specs-------- Int Exh
adv dur. 274 276
dur @ .050 224 224
valve lift .574 .566
Lobe Sep: 114.0
.....where is that cam being sold?!
THAT'S THE CAM I HAD!! NO ONE HAS RUN THAT THING YET!!! NO WAY!!
it's based off the trasher race cam (TEP) with some more intake lift. it will be a mean, MEAN cam. it will also go absolutely awesome with a turbo setup...that you have...
yes...but that's my cam. there is no doubt about it. it's a one off. is someone selling that on clubgp? is dustin selling that?
its in canada, it comes with 130# springs
i really really dont want to take the heads off my car yet, can this be ran with stock heads with the 130s? (rollermaster aswell)
wat about pushrods and such
ps how about idle
and yes i know heads would be great, but im waiting for winter for that,
yes, the indicated overall lift is on the stock 1.6:1 rockers.
if it were ME doing this, i would buy a set of heads on the side and get them ported, polished, and the guides milled down to run the cam properly. this cam is an awesome one for you to stumble upon for your setup and it'd be a waste for you to not use it to its' full potential.
however, if you get ahold of 3800 performance you can buy their 'TEP cam install kit' which would give you everything you need to run it.
im going to be getting heads done this winter, as i said before. afaik the heads are good for 600 lift with the 130 springs.
