would the dashpanel from the sedan fit the two door coupe?
spider4
Finding a two door coupe in my local junk yards is hard.and having a dash panel delivered is pretty expensive. So was wondering whether the dash panel from a 4 door model would fit. And if so what years would be compatible? I have the 97.Also if it is compatible would i also have to find one with the heads up display or would i be able to take that piece off of mine and put it on the donor dash?
Thanks.Good to know.I guess if i want to keep the HUD i need to find one that had it.Was wondering how hard it will be to take out/install?
You don't need to find one with the HUD, as far as I know. Should just be a hole in the dash that the hud bezel sits over. If you find one without a HUD, just cut the hole in. Plenty of people have installed HUDs in dashes that never had them. So should be doable.
