Worried about clutch slippage?
natethegreat
I just installed a zzp shift kit and followed directions, put the shims on, one underneath and one above the piston, made sure to set the lines and all that. But... it doesn't really feel any different? Im also really worried that the clutch's are slipping , but im not totally sure what that feels like. It also appears ive developed a small leak on the pan, so do i have to drop the pan and do it over again? Thanks!
did you clean up and reuse the stock gasket or the **** on that comes with a filter kit?
did you torque the bolts down?
Reused the stock gasket and i did torque them down. Right now it appears its just dripping from spillage when i dropped the pan but well see. Ill just keep an i on it.
Well thats good to hear now, that i literally just got done installing it. Its whatever, changed the fluid and got a new filter.
