KCprix
2 part question...
1st So I assume my 07 GrandPrix 3.8L NA base model does NOT have special ride and handling suspension, but how do I verify this before taking the car apart? VIN or any identifying tags/marks?
2nd In researching rear brake calipers to buy the "WITHOUT special" uses a metal piston. And the "WITH special" uses the phenolic piston. I am seeing metal may be the best (also $20 higher than phenolic)
But does it matter which is used?
Do they both fit?(autozone says yes for both)
Is it performance vs longevity, or just use what I want?
I am planning a rear brake job with both calipers and only have access to 1 vehicle and want to order the correct parts before taking it apart.
