In the engine bay fuse box can someone tell me what these pins go to, this is on the middle plug (orange on the 1998 GTP).
Pin B1 wire color Grey
Pin C2 wire color yellow
Pin D8 wire color green
Pin E8 wire color 2 green wires
Pin F3 wire color Brown/White maybe Change oil soon?
Is it possible these all go to the computer IE boost, MPG and fuel miles to empty, I put a 1998 3.8 GTP engine and trans into a SE body.
If so then I do not need these wires as the SE does not have a display like the GTP had but I would like to put in at a later date.
I have not put the power to it yet but just want to make sure before I do and possibly smoke something, I took the fuse box from the GTP and put it in the SE so the engine harness wires would be correct.
