Window Problems
Lawenforcer
Today, I was heading to work and rolled my drivers side window down. It went down just fine but didn't want to roll back up. I think the motor is fine cause after pushing the button up SEVERAL times it finally went up. So it will roll down just fine just not up. I am thinking maybe a bad switch in the controls, all other windows go up and down just fine on those same controls. Any suggestions before I go buy parts that I don't need. Thanks again for all the help...
Try lubing the window guides w/ something like WD-40 (everyone has this) and run the window up and down a bit and see if it frees up. Could be a switch but a lot of times it a sign that the guides are dry and the glass is sticking to it.
Problem solved....It was indeed a bad switch...I just bought a used master switch of ebay and fixed the problem....
