ptnothere
Hi all, I need some help please...
The driver window of my 02 GT 2dr is having issues.
The window doesn't always respond when the up switch is pressed. It is slow when it does respond. Going down it works fine every time but coming back up it only responds about 50% of the time. If you wait a few seconds then try it most of the time it works fine. The motor has also recently started making strange clicking/ticking noises even when nothing is pressed and it has now twice wound the window down with no buttons being pressed!
I have switched the motor/regulator and have done the window switch cleaning operation off: http://www.grandprixforums.net/window.php
Please can someone provide some guidance of what to try next?
Thanks
Phil
Thanks
Phil
