Wierd things happening, I need help
thatguy
Yesterday I replaced the top of door weatherstrip on my 2000 gtp. Which meant I had to pull the door panel off. Not all the way off but enough. Later on I come to a stop sign and my radio shuts off. Also my door locks do not lock and my power seat does not work or have heat. When I press the lock and unlock it clicks but does not do anything. My windows and mirrors work. It didnt have these problems right after I was finished with the weatherstripping. I went several places and logged probably 40 miles and it just happened. I checked the fuses and even replaced them to see if that was the problem but that did not solve anything. Could anyone help me, what is going on with my car? Thank you
I would say to check your grounds first, but it sounds like you probably nicked a wire. Did you have a knife/ or screwdriver anywhere near wires? Did you let the door panel hang?
I didn't use a knife or anything and I sort of left it hang, it wasnt disconnected off the top at the window. Just the clips were popped loose
