but why they do the same thing all i need to know is if im running lean or rich to be more persice id just use my scanner ir a aeroforce
I have an AFR gauge in my 2000 and all I can tell from it is that my O2 sensor seems to have ADHD. Bounces around everywhere. Pretty useless even to see if you are running lean or rich, as it pretty much says both.
There is a lot more too it than you just being lean or rich. You need a wideband to tune your maf properly and you cannot do it just by seeing if your car is lean or rich. Also you want a non intercooled car at an 11.5 afr at wot and an intercooled car at 12 afr. You would not be able to get exactly those numbers with you just seeing that it's either rich or lean.
Sent from my ADR6400L using Tapatalk 2
This.If you can't afford a wideband, you can't afford to mod.
Stock Narrowband sensors have switch points when your car is running in closed loop. Run an open loop tune and you won't see the switching (ADHD)
well id get the wide band ad on kit for the scan gauge i want but ok
