http://www.grandprixforums.net/threads/84845-Wide-Band-Logging-thru-EGR-using-UVScan
here is my writeup i did. DHP's data logger is very buggy and looses data. so if you aren't already using UVscan you really should change. you can data log by using the A/D inputs on the DHP but that gets messy with wires. this writeup explains how to tap in to the EGR connector and log the wide band thru it.
Thanks for the info but I'm not sure the egr method will work for hooking up the wideband since my egr system is still functional. That's why I was going to log with the DHP though the analog connection. Is their any other way besides disabling my egr?
