Which TB and more?
fratzke7
Look in my sig for mods...I'm thinking it is time for a TB and maybe some injectors, fuel pump re-wire????? I'll take any suggestions :) Oh and I'm going to spend up to $1k this time around...hopefully :D
injectors might be a next step, but have you looked into an intercooler? it is really the only big mod you have left to do. im not sure that i would buy a throttle body, but just port your stock one instead. unless you have a port matched blower case then the throttle body isnt going to do you any good.
Spray = LAME :p
I'd go with a Ported Inlet/Outlet Gen III, LS1 TB, 42.5# Injectors, and a custom Tune :D
buy an intercooler before you think about that other stuff. trust me, the car will be a crazy amount faster with just that, a smaller pulley, and a tune.
i would recommend a ZZP fullsize stage 2, but from just looking at their site it says out of stock? wtf?
Before the IC, you'll need injectors I bet. I bet you're close to maxing them out now as you set. If you do an IC first, I wouldn't drop pullies until you AT LEAST do some 42.5 Inj and a good fuel pump rewire. Scan Scan Scan
Oh and if you do an IC, get a Full Sized and not an SS. An SS would be half assed doing it IMO. With those mods, you need the Full Sized (actully, EVERY GP needs the Full Sized IC)...
Spend your money on bigger injectors, first! Then go with a larger TB and port work. I made the mistake of not using bigger injectors and ended up leaning out and chipping 3 pistons. Me being cheap/stupid and not spending $250 on injectors ended up costing a lot more, and I still am going to need those injectors to be safe with my new build.
I went with bigger injectors early with my car. Get em and the cost will far outweigh the possible negatives. I threw on biger injectors and fuel rails. Now I am starting to drop pulleys and have plans to IC this summer and I dont have to worry about fuel.
