I want to get a 180 tstat for my car, but which would be better? Intense offers one, and so does zzp. does anybody know if one is better than the other?
It'll take longer to heat up. It's drilled out so it can't completely close.
The 180ºF thermostat was modified by drilling four small hoses around the thermostat body to permit a small amount of coolant flow through the cooling system even when the thermostat is closed. This modification results in reducing the thermostat's opening reaction time when the engine is relatively cool to begin with and is then challenged with prolonged wide open throttle runs. Without a drilled thermostat, the temperature of the cylinder heads can become quite elevated before the thermostat has a chance to open and establish coolant flow through the heads to cool them down.
Does anyone know why they want to get a cooler t-stat? Do you know why you want your engine cooler?
Thus you should be able to run a stock t-stat and get better mileage and better performance.
you do know cars are faster when the engine is colder, right?
Only if the car is set up for it, and even then engines are typically most efficient right around 200°F.
