which springs?
Akuch26
Hey guys I'm looking for a good stiff set of springs that are stock ride height. Would comp g ones be the best to get?? Or are there any other springs that would be recommended ? Thank you!
04 grand prix gtp non comp g.
I'm also going with the kyb struts
Are you sure?
____Ridin On Chrome posted this in an old thread____
Front Springs:
22133031 FKN Highest Rate
22133030 FKJ compG
22133029 FJT
22133028 FJS stocker for 99gtp
22133027 FJR Lowest Rate
Rear Springs:
10258880 TDJ Highest Rate come on 04+ comp handling package
10258879 TDH
10276574 TFY stock rate for my 99gtp
10276573 TFW Lowest Rate
I don't even know why I posted that. But those are some good part numbers. I'm pretty sure the consensus was, they are the same and the sruts were different
It looks as if you have the FE2 suspension(ride and handling) then you have the front 22133030. It appears they are shared with the FE3 suspension.
But...for the rears there are two different numbers that come on the FE3, 10258880 and 10258881.
10258880 cost more, so it has to be better...right?
