which sensor plugs into the speedo on the driveshaft?
not sure if this is what you want. here's the link were I got it..http://www.justanswer.com/pontiac/3kko1-speed-sensor-located-1999-pontiac-grand-prix.html
sorry I can't help you out there. Isn't one close to it with the right looking connector. did you just swap engines?
Hopefully someone with the know how jumps in
If I recall properly, it's on the part of the harness that goes over top of the motor and down the back side to the knock sensor at the back of the block. It should be on that area of the engine harness. Its either there or connected to the chassis next to the power steering pump. I would check but my engine is still out of the car at my buddies house.
