Which MOOG LCA?
FordMan77
Active member
Getting tired of the clunking in the front end and after 290K I'm sure the LCA's need to be done as I'm not sure if the prev. owner ever replaced them. I did a ball joint on the pass side a while ago but that's it.
Want Moog LCA's, but why the huge price difference on RockAuto between the 2 "Problem Solver" LCA's? One is $79.79/side and the other is $97.79. Per the description on RA they both appear to be the same. Anyone have any knowledge on the 2 they care to share before I drop the coin?
[TABLE="class: dxgvTable_FMecat"]
[TR="class: dxgvDataRow_FMecat"]
[TD="class: dxgv"]K80539[/TD]
[TD="class: dxgv"][/TD]
[TD="class: dxgv"]Front Left Lower; Problem Solver - incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Incl. bushings; Pending Supersession to CK80539
[/TD]
[/TR]
[/TABLE]
[TD="class: dxgvIndentCell dxgv"][/TD]
[TD="class: dxgv"] CK80539[/TD]
[TD="class: dxgv"]Front Left Lower; Problem Solver - incl. powdered-metal gusher bearing to allow grease to penetrate bearing surfaces; Incl. bushings[/TD]
[/TR]
[/TABLE]
As per Federal-Mogul Resource Center - Vehicle Look-up.
AKA Federal-Mogul catalog.
R series is budget quality and budget warranty.
https://www.rockauto.com/catalog/moreinfo.php?pk=3443733&cc=1374779
Moog R-Series Control Arms combine quality design and construction with pricing that will appeal to budget-minded vehicle owners.
MOOG Warranty Information
Limited lifetime (except tools & Omega power steering products). Hub assemblies, steering dampers, and R-Series 12 months.
