where to get these parts?
jman44
The T under the s/c snout and the other plastic connector near the throttle body. its like a 180. both of these are broke on my 99 gtp and I have been to all the auto stores in my area. They don't carry the parts. Anyone have any ideas where I can order them off line.
advance auto has the best T's ive found, small white T's 2 per pack for 2 bucks. add some vac line to tie it back into the factory lines, or just replace all the lines with new vac lines.
# 558 should be the one you are referring to. GM# 24508742 should help you find a replacement if you don't want to build your own.
Retail for it from a dealership is almost $50 but you could get it less online I'm sure.
If it were me, I would just build my own, for $10-12 with replacement parts left over.
with the pack of T's it cost me about 5 bucks with vac line to redo most of my vac lines. even replaced the fat evap line off the TB for the same 5 bucks. vac line is super cheap per foot, 4 feet should do all of them.
