Where is this water coming from?
CBWhite
When I park my car facing up hill it'll leak water on the passenger side floor not much, but enough to be a pita. When I park it facing down hill i'll hardly see a drop. What the hell's going on here? It's not coming in through the door dripping down by speaker area. I've heard of that problem. Believe me I've got the door sealed up tight. On top of that one time I had some under my rear seat cushing that I have yet to figure out how it got there. Also it's not coming from up front because when I pull up the carpet you can feel what areas wet and what isn't. It's coming from the right side somewhere, but it's not the door.
That's not the problem. I already have that part. I've had it for 5 or 6 years now. It's not leaking from up front. It's on the side somewhere. It's hard to diagnose it using a water hose because a hose just doesn't show it the way rain does. Rain water is steady and over several hours. Where you'll get a slow drip.
Yes, but I pulled down part of the headliner on and the drainage connections looked fine. Unless it's leaking pass them somewhere.
Usually the hoses will get debris in them and it will back up and leak inside the car. Never seen it on a GP but on tons of other cars when I used to install them. Use compressed air to blow them out.
Jeff
