I got a o1 Grand Prix GT(2dr) and need to change the thermostat, but dont know were its located. Could somebody please help me with the location & how i go about fixing it. Thanks!:th_scratchhead:
follow the upper rad hose to the LIM (block), and there are 2 bolts on housing that holds the thermostat
Well...are you leaking any coolant? How many miles also??
But it could just mean you need to bleed the coolant if you've been fooling around with it. Sometimes people don't know to bleed it and it can cause temp. to fluctuate some.
not a problem
after you replace it, just make sure you bleed the system of air to insure that it dont overheat on you.
There is a bleeder screw on top of the housing that you open 1-2 turns and with the car running you let it heat up and wait for coolant to start streaming out of the bleeder. Wait till its a steady stream, because you want to make sure all the air gets out, it may take 5-10 mins but its no big deal. Then just close it up and take it for a drive to see if it helps.
if itsn't the thermostat, pump or fans or something like that...might want to look into your LIM gaskets. i know Austin had lots of overheating problems and it turned out his LIM gaskets were the culprit. but regardless you should already have these gaskets replace as maintenance.![]()
I wouldn't think it's a thermostat or LIM gaskets.
If the car cools when under power (more heat generated in engine) and has airflow through the radiator, yet heats up when sitting still. That would usually be an airflow problem. Depending on how much it's heating up (fans come on at ~216F and ~228F on most stock tunes).
I'd be checking the fans and fuses to them, as well as confirming the pcm is seeing the same temps as the dash.
