Where is my antenna?
yormets
My radio don't work worth a damn with the stock antenna attached. AM not at all. I've looked all around...where is the antenna?
2007 Base Model
I'd say check the connections, its at the very top of the rear window, as well as at the back of the radio. Clean any corrosion you may find. If still no luck, use a multimeter to test for conductivity to make sure the wire isn't broken anywhere. If that all checks out, I'd suspect a bad radio, or you live in the middle of the desert.
Check your connection at the back of the radio, in my 04, the plug has to be seated just right or the signal will be terrible. On a clear night I can receive AM signals from Boston loud and clear, NYC, D.C., and Bermuda also come in, with varying degrees of success. I am in east central Maine. From Mt Cadillac in Bar Harbor Maine, I can receive FM signals from Halifax NS and St. John NB, usually just before dawn.
