Where is Crankshaft Position Sensor Located on 04 grandprix gt
mikev14
Im trying to find the location of a Crankshaft position sensor on my grand prix gt 04 cause my engine has been turning off whille running for about 15-20mins and then it will turn on after 10-15 of cool time and already checked the gas pump and coils and there fine so this is my last option to trying to fix the problem
please help
detail and/or pics will be of great help
Crank sensor
It's location on the motor
In front of it is the plastic shield
And balancer (M6-1.00 - ~75mm bolts)
does that mean taking off the belt in order to get to the sensor, I have the same problem.
It's not on the bottom of the car right? It's on the side close to the water pump, right?
Yes, you have to remove the belt, the splash sheild in the pass. wheelwell, the harmonic balancer from the crankshaft, then the plastic cover for the CKPS. You need a puller w/ the correct size bolts to remove the balancer correctly. Search for it here, I know it's been posted recently.
